You are here: PSPad forum > English discussion forum > How to add CRLF in a .DEF file?
Posted by: therium | Date: 2023-07-08 14:00 | IP: IP Logged
I have PSPad v5.0.0 (277) on Windows 11.
I have a this code in the Context\Markdown.def file:
[divhidden | divhidden ]*Ctrl+'
<div style="display:none"> § </div>
[image | image ]
 In the first defintion for "divhidden" I want to insert a blank line after the </div>. I have saved the Markdown.def file and restarted PSPad. It inserts all text correctly but not the extra line after the </div>. How do I insert a blank line after the </div>?
Thank you!
EDIT: OK I copied and pasted the .DEF contents and the forum appears to put in extra blank lines.
Edited 1 time(s). Last edit at 2023-07-08 14:00 by therium.
