You are here: PSPad forum > English discussion forum > Re: Log Parser Color
Posted by: mce | Date: 2023-06-20 12:21 | IP: IP Logged
Hi Jan,
For a very long time I was using previous version 4.6.1 of PSpad and recently I tried the newest version 5.5.1, I like that is much faster when opening and closing with many files open.
But I have a problem: I cannot seem to be able to change the Log Parser background color, it's always white, how can I change it?
I tried the Program Settings->Colors->Log Parser but it's not taking it.
For the Highlighter that I use there is no Log Parser separate entry in the Colors.
Thanks,
Cristian
Posted by: pspad | Date: 2023-06-20 13:27 | IP: IP Logged
5.5.1 32b version supports themes in program settings / Color. You can set whole IDE into dark color.
Posted by: mce | Date: 2023-06-20 16:27 | IP: IP Logged
I want to have different colors for different highlighters, and the log parser should match the highlighter background preferably, a theme probably applies to the whole editor, no?
There is a Log Parser color setting, what is that used for?
Thanks,
Cristian
Posted by: mce | Date: 2023-06-20 16:36 | IP: IP Logged
I tried and loaded a few themes, the log parser is still white
Thanks,
Cristian
Posted by: pspad | Date: 2023-06-20 17:31 | IP: IP Logged
You need to set PSPad IDE style in the Program settings / Colors
Posted by: mce | Date: 2023-06-20 19:46 | IP: IP Logged
It is set to Windows, which is default value. Shall I try a different one?
Thanks,
Cristian
Posted by: mce | Date: 2023-06-20 19:55 | IP: IP Logged
Different styles indeed have different colors for the log parser, but still cannot be configured to a different color then default, at least is not white!
It would be nice if it followed the "Log Parser" color in the Colors setup, that entry doesn't seem to be doing anything.
Also, most of the time when I change the styles I get a terminate message and PSpad crashes.
Thanks,
Cristian
