You are here: PSPad forum > English discussion forum > Re: Sidebar file list
#1 Sidebar file list
Posted by: loj | Date: 2023-06-02 18:55 | IP: IP Logged
Something weird just started happening this morning, in 5.0.7 (775). The file listing in the sidebar, when using the folder browsing mode, seems to have forgotten how to display files. The folder tree displays normally, but at first the file list pane was completely empty. Restarting PSPad had no effect. I restarted the computer, and part of the list came back -- just the column labeled 'Type.'
#2 Re: Sidebar file list
Posted by: pspad | Date: 2023-06-03 09:02 | IP: IP Logged
It looks like the file list is there, but you changed width of columns to zero.
You can move your cursor to begin of the header - next to left border and cursor should change to "column width" symbol. Now drag it to to the right. Repeat it as you will see all columns.
#3 Re: Sidebar file list
Posted by: pspad | Date: 2023-06-03 09:14 | IP: IP Logged
As alternate, close PSPad
open %APPDAta%\PSPad\PSPad.ini in Notepad.ini (or in any other editor, not PSpad)
find section [FilePos]
Delete entries
WidthFileName=nn
WidthFileSize=nn
WidthFileDate=nn
and start PSpad
I will do change to set some minimal width for it.
#4 Re: Sidebar file list
Posted by: loj | Date: 2023-06-04 05:50 | IP: IP Logged
Yep, that did it. Thanks, Jan!
