You are here: PSPad forum > English discussion forum > Re: Fails using CTRL+Del
#1 Fails using CTRL+Del
Posted by: Marcos | Date: 2023-05-17 23:02 | IP: IP Logged
on a line that contains several spaces and then a word. I would like to use CTRL+DEL to delete the spaces until the next word. when I use CTRL+DEL the editor deletes the cursor spaces forward including the next word. I would like you to delete only the spaces.
Example:
01 test
in this line I have 10 spaces + the text "01 test"
if at the beginning of the line I use CTRL+Del the PSPAD erases the forward cursor spaces and the text "01 "
This worked perfectly until version 4.5.7 (2450). After I updated to version 5.0.7 (731) it stopped working.
#2 Re: Fails using CTRL+Del
Posted by: pspad | Date: 2023-05-18 03:12 | IP: IP Logged
Why don't you use Del to delete one space or one char?
#3 Re: Fails using CTRL+Del
Posted by: Marcos | Date: 2023-05-18 13:15 | IP: IP Logged
hello,
Precisely because I want to delete all the spaces until the beginning of the next word.
Remembering that in version 4.5.7 it worked perfectly. Only after updating it stopped working.
I looked for some configuration, but I didn't find anything about it.
Marcos Alija Ramos
#4 Re: Fails using CTRL+Del
Posted by: pspad | Date: 2023-05-21 14:05 | IP: IP Logged
OK. It should behave that forst it deletes all spaces and next it will delete word e.t.c. right?
#5 Re: Fails using CTRL+Del
Posted by: Marcos | Date: 2023-05-22 14:52 | IP: IP Logged
Exactly.
The correct is:
By pressing CTRL+Del, delete all spaces from the cursor until the next word.
If you click CTRL+Del again, then delete the next word.
Remembering that in version 4.5.7 (2450) it already worked that way.
Marcos Alija Ramos
Brazil.
