You are here: PSPad forum > English discussion forum > Re: last line in txt-file
Posted by: ragestu | Date: 2023-04-15 16:08 | IP: IP Logged
In version 5.0.7 (775) the last line of a text file is not displayed if it is empty. This behavior is the same in the 32bit and 64bit version. Is there a setting here that I don't know about, or is there a problem here.
Posted by: pspad | Date: 2023-04-16 05:48 | IP: IP Logged
it was fixed in the current developer build
Posted by: Libia_Casper | Date: 2026-06-29 09:10 | IP: IP Logged
One other thing to try is resetting PSPad's user configuration or testing with a portable copy. That can quickly tell you whether the issue is caused by a corrupted setting rather than the editor itself. It's saved me a few times with strange behavior.
