You are here: PSPad forum > English discussion forum > Re: Drag'nDrop Text diff missing
Posted by: cdeibert | Date: 2023-03-22 15:01 | IP: IP Logged
Hi, first of all: This is a great piece of software and I still prefer it over Notepad++.
My question: Since I upgraded to 5.0.7 (775) I do miss (besides dark mode...
) the great Drag'nDrop-Function for comparing files: Will this come back?
Thanks!
Posted by: pspad | Date: 2023-03-22 17:35 | IP: IP Logged
Drag&Drop function is still there, but I found it hides in the left top corner
The box appears when you Drag your file over menu + toolbar + file bar
Posted by: cdeibert | Date: 2023-03-23 09:21 | IP: IP Logged
You're right, the message did move from right to left, you now need to drag the file to anywhere in the GUI: Don't know if this is a better behaviour? Besides the box is a step backwards when it comes to aesthetics, but I guess this does have sth. do to with the "bye-bye dark mode"...Thanks.
Posted by: pspad | Date: 2023-03-23 09:32 | IP: IP Logged
I didn't know it too till you told me it
I must investigate what happened
Posted by: pspad | Date: 2023-03-23 10:31 | IP: IP Logged
Next build will be modified - Drop Window will appear in the cursor position, it doesn't mater if you will drag file from the left/right of PSpad
