You are here: PSPad forum > English discussion forum > Re: Modified lines indication
Posted by: Piotr | Date: 2023-03-16 21:13 | IP: IP Logged
pointing out the modified lines is a great idea!
Thank you
But what bothers me a lot (sorry) is the line thickness.
Can I change the highlight thickness of a modified line somewhere?
Can I move the line to the left of the line number?
Thanks for the answer!
Thanks for a great editor
Posted by: pspad | Date: 2023-03-17 07:01 | IP: IP Logged
Now there is no possibility to change thickness of modified line indicator.
I can do it. But placement and thickness is same, according to other applications.
Move it before line numbers is possible, but there are other signs, e.g. - bookmarks, code folding...
Do you mean it too thick or too thin?
Posted by: Piotr | Date: 2023-03-18 19:41 | IP: IP Logged
It's too thick for me.
It disturbs the view to which I have become accustomed over the years.
But the idea itself is great!
PS Sorry, my english is google translate
Posted by: pspad | Date: 2023-03-20 08:53 | IP: IP Logged
Next build:
New option in Program settings / Code folding - Modified line indicator width. If set to zero, indicator is switched off
Posted by: swbrains | Date: 2023-10-24 03:13 | IP: IP Logged
Is this option still located here? I can't find it under Program Settings->Code Folding.
Posted by: swbrains | Date: 2023-10-24 18:22 | IP: IP Logged
swbrains:Is this option still located here? I can't find it under Program Settings->Code Folding.
Nevermind -- I needed to update the latest developer build to access this setting.
