You are here: PSPad forum > English discussion forum > Re: List of FTP connection in popup menu - break after each 15 connections
#1 List of FTP connection in popup menu - break after each 15 connections
Posted by: Piotr | Date: 2023-03-16 21:07 | IP: IP Logged
how to restore previous appearance (with scrolling)?
You can't change long-term habits smiling smiley
Thanks for the answer
#2 Re: List of FTP connection in popup menu - break after each 15 connections
Posted by: pspad | Date: 2023-03-17 07:02 | IP: IP Logged
Isn't better to see all FTP connection in once instead of scrolling?
#3 Re: List of FTP connection in popup menu - break after each 15 connections
Posted by: Piotr | Date: 2023-03-18 19:36 | IP: IP Logged
For me it's better to scroll smiling smiley
This change is something like moving the Joomla 4 backend menu from top to left: it was a great solution for years...
Habit is second nature to man smiling smiley
#4 Re: List of FTP connection in popup menu - break after each 15 connections
Posted by: pspad | Date: 2023-03-18 19:48 | IP: IP Logged
I will add option for connection break.
#5 Re: List of FTP connection in popup menu - break after each 15 connections
Posted by: Piotr | Date: 2023-03-18 19:53 | IP: IP Logged
Thank you very much
#6 Re: List of FTP connection in popup menu - break after each 15 connections
Posted by: pspad | Date: 2023-03-20 08:06 | IP: IP Logged
In the next build will be added option in the [Special settings] section (Program settings / Direct edit button)
BreakFTPConnectionEach=15
When you set
BreakFTPConnectionEach=0
it won't break list of the connection
#7 Re: List of FTP connection in popup menu - break after each 15 connections
Posted by: Piotr | Date: 2023-03-21 14:48 | IP: IP Logged
Thanks
