You are here: PSPad forum > English discussion forum > Re: UNIX Shell Script enabled by default in Highlighter Settings
#1 UNIX Shell Script enabled by default in Highlighter Settings
Posted by: MASH73 | Date: 2023-02-19 13:11 | IP: IP Logged
Hi there,
is there a reason for why UNIX Shell Script in Settings\Highlighter Settings is enabled by default always ?
It's possible to disable, but it's enabled again once PSPad has been closed and started again.
Using PSPad 5.0.7 (757)
#2 Re: UNIX Shell Script enabled by default in Highlighter Settings
Posted by: pspad | Date: 2023-02-20 05:14 | IP: IP Logged
It's a bug. Thank you for info.
#3 Re: UNIX Shell Script enabled by default in Highlighter Settings
Posted by: pspad | Date: 2023-02-21 09:39 | IP: IP Logged
Fixed. Available in th enext build
#4 Re: UNIX Shell Script enabled by default in Highlighter Settings
Posted by: MASH73 | Date: 2023-02-21 14:04 | IP: IP Logged
Thanks smiling smiley
