You are here: PSPad forum > English discussion forum > Re: Delete spaces
Re: Delete spaces
#1 Delete spaces
Posted by: Galizia | Date: 2023-01-07 11:57 | IP: IP Logged
Hi, sometimes i find several lines on a document than only contain spaces, not followed by any text character.
Is it possible to delete all this spaces but without deleting the lines that contain them or modifying any other line that start with spaces followed by any character?
Thank you very much !
#2 Re: Delete spaces
Posted by: pspad | Date: 2023-01-07 15:34 | IP: IP Logged
Menu Edit / Lines manipulation / Remove redundant spaces
If you use this function often, you can add shortcut for it in the program settings / KeyMap
#3 Re: Delete spaces
Posted by: Galizia | Date: 2023-01-07 22:00 | IP: IP Logged
Thanks
