You are here: PSPad forum > English discussion forum > 4k display tip
4k display tip
#1 4k display tip
Posted by: karelt | Date: 2022-12-20 13:48 | IP: IP Logged
Hope someone will find this useful.
To use PS Pad on a 4k display with 3840x2130 resolution and 150% (Recommended) Scale and layout in Windows' Settings/Display, I made the following changes:
Set the app default font (Format/Font) to Lucida Console-Regular-12. This font scales nicely in Windows.
Set larger toolbar icons: Settings/Program Settings.../Program (part 1)/Toolbar icon set: PSPad_32 (wish someone has created 32 height version of "PSPad classic" icons though, sigh)
The menu font is a bit small for my taste, but not too uncomfortable. Also enlarging it via high dpi settings override causes way too much fuzziness in the editor font so this seems like a good trade-off until a better solution pops up.
smiling smiley
K
#2 Re: 4k display tip
Posted by: Libia_Casper | Date: 2026-06-30 14:25 | IP: IP Logged
Windows High DPI scaling can be really harsh on older desktop apps, and using the Windows override definitely makes the text way too blurry.
The PSPad_32 icons are a lifesaver on a 4K monitor. If you ever get tired of Lucida Console, I've found that 'Consolas' at size 11 or 12 also handles the 150% Windows scaling surprisingly well without looking jagged. It's a good trade-off to keep the editor crisp!
