You are here: PSPad forum > English discussion forum > Re: double accent virus
#1 double accent virus
Posted by: Esgrimidor | Date: 2022-12-08 21:35 | IP: IP Logged
Some days ago appear in pspad.
Initially I suppose it was the old virus double accent, but no.
I think some years ago I have the same problem in pspad. I don' remember well.
So may be :
The recent change to a different character set to read chinese and russian.
I remember the last time was complicated until this problem was solved....
Don't happen in notepad of windows 10
don't happen in microsoft word
only detected in pspad
Take it easy. Is necessary i will put the same ascii character set again.
I don't understando nothing
happen again after return to ascii....
Nice program indeed
#2 Re: double accent virus
Posted by: Esgrimidor | Date: 2022-12-08 21:36 | IP: IP Logged
I will try simply reinitiating also.....
Nice program indeed
#3 Re: double accent virus
Posted by: Esgrimidor | Date: 2022-12-09 20:33 | IP: IP Logged
I think is some other software incidentally interfering with pspad.
Resident program
How can I see in windows 10 the last programs I have closed ?
Best Regards
Nice program indeed
#4 Re: double accent virus
Posted by: Esgrimidor | Date: 2022-12-11 11:10 | IP: IP Logged
I have found at least two tools
Start - Execute - Shell:recent
to see history archives
and a nirsoft program to see programs
executedprogramslist
I haven't solved my problem, but I will inform is solved.
Best Regards
Nice program indeed
#5 Re: double accent virus
Posted by: pspad | Date: 2022-12-11 13:56 | IP: IP Logged
In phe past i had problem with preinstalled PDF Factory. It prevents to write accented chars and doubled accent signs
