You are here: PSPad forum > English discussion forum > Re: Also assign Shift+Backspace to DeleteLastChar?
Posted by: lphilpot01 | Date: 2022-11-29 04:50 | IP: IP Logged
Is there a way to have Backspace AND Shift+Backspace both assigned to DeleteLastChar? It's just sloppy typing on my part but I find that I sometimes have the Shift key down when I'm backspacing and it goes nowhere when that happens. However, there's only one shortcut assignable to DelteLastChar.
Is there a way to assign more than one?
Thanks.
Retired ... finally!
Posted by: pspad | Date: 2022-11-29 09:17 | IP: IP Logged
You can't assign 2 shortcuts to one command, but it's possible to write simple script with your shortcut, what will call delete last char.
Prerequisities:
32b PSpad version
Scripting is enabled in the Program settings / System integration
Open new file with .VBS (visual basic script) extension
Put following content into your file:
Sub ShiftBckSpace
If (editorsCount = 0) Then
Exit Sub
End If
Set editor = newEditor()
editor.assignActiveEditor
editor.command(ecDeleteLastChar)
end sub
menu items sub Init addMenuItem "Shift+BackSpace","", "ShiftBckSpace", "Shift+BkSp" end sub
Save this file into PSpad subfolder:
.\Script\VBScript
After recompilation from the menu Script or new PSpad start you should see in the menu Script new item Shift+BackSpace and your Shift+BackSpace should delete last char same as BackSpace
Posted by: lphilpot01 | Date: 2022-12-02 04:08 | IP: IP Logged
Pre-reqs are met, but with the code copied verbatim, I get these two runtime errors:
Description: Variable is undefined "menu"
Description: Variable is undefined "items"
So I assumed the line "menu items" was meant to be a comment and made it one (i.e., 'menu items).
Then I get this error:
Module name "" isn't unique
I commented out the default "option explicit" line (from the VBscript template) thinking it might relax the syntax requirements, but I still get the same error. Does it need a specific module name?
Sorry, but it's been YEARS since I last looked at VBscript and only briefly then. If it was a Bash script I could probably debug it myself. Probably...
Thanks!
Posted by: lphilpot01 | Date: 2022-12-02 04:15 | IP: IP Logged
Small update...
After looking at the other script I added a line Const module_name = "ShiftBackspace", which fixed the last error. But when I try to use Shift+Backspace, I get this runtime error:
Module: ShiftBackspace
Line: 11 Pos: 1
Description: Invalid procedure call or argument
'editor.command'
Maybe I've introduced a namespace issue now? At any rate, I don't know VBscript and obviously I'm not fixing it, so I'll wait for the real answer.
Thanks!
Posted by: pspad | Date: 2022-12-02 06:06 | IP: IP Logged
Hello, change it to:
editor.command "ecDeleteLastChar"
Posted by: lphilpot01 | Date: 2022-12-02 16:31 | IP: IP Logged
That did it. I also added "Dim editor" at the top to resolve one other error but it's working now.
One question - Is there a place (maybe under %APPDATA%) I can put this script where it won't be affected by upgrades? There's no scripts folder by default under my profile.
Thanks!
Posted by: pspad | Date: 2022-12-02 19:10 | IP: IP Logged
Your script, if you create new file won't be attached by updates.
User defined folders are in ToDo but not finished yet.
