You are here: PSPad forum > English discussion forum > Re: Ftp client
Re: Ftp client
#1 Ftp client
Posted by: Titeuf1 | Date: 2022-10-24 07:31 | IP: IP Logged
Hello everyone !
After using Pspad for years, I reinstall the software on a new computer.
I want to use the ftp client and on the native install it bugs on every attempt while through Filezila I normally connect to the remote server.
The hosting company uses port 22 for the connection.
Outside of the classic way, we must use port 21.
I don't know and I couldn't find where to configure this change.
If someone has 5 minutes of their time to tell me if it's possible and where, that would be really nice.smiling smiley
#2 Re: Ftp client
Posted by: pspad | Date: 2022-10-24 08:46 | IP: IP Logged
You can transfer FTP client settings (or all settings) from previous computer useing the menu Settings / Backup
Backup configuration / Restore configuration
Or you can import Filezilla FTP settings into PSPad - pon the form, where is list of FTP connection is Import button. Choose FileZilla format and let PSpad import settings.
It look slike you use active FTP connection. In your PSpad FTP settings uncheck "Passive mode"
#3 Re: Ftp client
Posted by: Titeuf1 | Date: 2022-10-24 11:57 | IP: IP Logged
When I disconnect passive mode I get the same error message either
530 Incorrect login.
Certification:
can't connect
LastError: 0
#4 Re: Ftp client
Posted by: pspad | Date: 2022-10-24 13:43 | IP: IP Logged
Are you sure the name and paasword are correct? What says FTP log (ctrl+L) in PSPad?
#5 Re: Ftp client
Posted by: Titeuf1 | Date: 2022-10-24 15:31 | IP: IP Logged
Yes I'm sure the name and pass are correct.
I re-parameterized them for more security.
In addition there is a particularity: If I connect with Filzila in fast mode it works. If I do it via the connection saved in a folder, it does not connect...
Just mad story winking smiley
#6 Re: Ftp client
Posted by: pspad | Date: 2022-10-25 08:10 | IP: IP Logged
Can you write me some password what contains all chars you use in your password?
Send it please to support mail, not here into forum. Don't send me any other connection information. I will try to simulate decryption and encryption of the password.
You wrote Filezilla doesn't work with your connection in all cases too. There must be "something"
#7 Re: Ftp client
Posted by: Titeuf1 | Date: 2022-10-25 12:20 | IP: IP Logged
Hi
Mail sent.
