You are here: PSPad forum > English discussion forum > Re: Replace with "NOTHING" (regex engine problem!!!)
#1 Replace with "NOTHING" (regex engine problem!!!)
Posted by: PSPad | Date: 2022-08-12 19:32 | IP: IP Logged
It says it has been changed 10000000x times, but it hasn't. Regex Engine PSPad bad.
Example:
replace with "NOTHING" (null)
But it works perfectly in Boost.Regex and Onigmo.
#2 Re: Replace with "NOTHING" (regex engine problem!!!)
Posted by: pspad | Date: 2022-08-12 21:47 | IP: IP Logged
What do you want to do?
#3 Re: Replace with "NOTHING" (regex engine problem!!!)
Posted by: PSPad | Date: 2022-08-13 11:57 | IP: IP Logged
This is some unknown INVISIBLE Unicode character and I want to remove it
invisible-characters.com
Edited 1 time(s). Last edit at 2022-08-13 11:58 by PSPad.
#4 Re: Replace with "NOTHING" (regex engine problem!!!)
Posted by: pspad | Date: 2022-08-13 12:43 | IP: IP Logged
^ means begin of line. Not an unknown unicode character
#5 Re: Replace with "NOTHING" (regex engine problem!!!)
Posted by: PSPad | Date: 2022-08-13 17:05 | IP: IP Logged
"^_"
_ <=== But "__" means any invisible character.
#6 Re: Replace with "NOTHING" (regex engine problem!!!)
Posted by: pspad | Date: 2022-08-13 20:36 | IP: IP Logged
Immediately after line begin
