You are here: PSPad forum > English discussion forum > Old files with german character set
Posted by: idefix2 | Date: 2022-07-19 12:33 | IP: IP Logged
Hi, I have to work on old MSDos files with the german character set. The character set is correctly displayed by "Ansicht-OEM Zeichen", but the characters become extremely ugly and hard to read. I have tried a number of alternatives, either I get too big or too small characters, with which it is nearly impossible to work, and if I try and chose a normal font like Lucida, the Umlauts are not displayed correctly.
Posted by: pspad | Date: 2022-07-19 15:35 | IP: IP Logged
In the Encoding menu choose correct German OEM encoding and press Ctrl+R (Reload file)
If you don't see your encoding, press the modify item (on the bottom) and enable code pages you want to use.
Posted by: idefix2 | Date: 2024-11-15 15:54 | IP: IP Logged
Can I change the default encoding of files depending on the file type?
Posted by: pspad | Date: 2024-11-15 16:26 | IP: IP Logged
No, there was no request for this functionality
