You are here: PSPad forum > English discussion forum > Re: Yellow / green changes indicator - Disable / change?
Posted by: lphilpot01 | Date: 2022-06-29 02:58 | IP: IP Logged
PSPad 5.0.7 (731) on Windows 11
Is it possible to hide the yellow / green vertical bar to the left of the first text column? Or if not at least change its color to something less noticeable?
I've looked through all the preferences and settings and if it's there, I've overlooked it.
Thanks.
Retired ... finally!
Posted by: pspad | Date: 2022-06-29 09:35 | IP: IP Logged
Hello.
I will add option to disable it.
Posted by: lphilpot01 | Date: 2022-06-30 22:16 | IP: IP Logged
Now that I think about it a little more, just being able to configure the color would be great. It's a useful indicator but IMO just too visually bright being yellow.
Thanks.
Posted by: pspad | Date: 2022-07-01 06:16 | IP: IP Logged
OK. I can do it automatically less bright with dark theme
Posted by: lphilpot01 | Date: 2022-07-02 18:02 | IP: IP Logged
Thank you!
