You are here: PSPad forum > English discussion forum > Re: Extract & Join - Bible verses, chapters etc.
#1 Extract & Join - Bible verses, chapters etc.
Posted by: PSPad | Date: 2022-06-17 13:31 | IP: IP Logged
I am looking for a script that will extract just the verses and join.
Main Source:
Isa 49:5-8 that formed.
Isa 51:5; 60:9; 66:19; Zep 2:11 the isles.
Jer 1:5 Before I.
The expected result should look like this:
Isa 49:5-8; Isa 51:5; 60:9; 66:19; Zep 2:11; Jer 1:5
#2 Re: Extract & Join - Bible verses, chapters etc.
Posted by: vbr | Date: 2022-06-17 18:33 | IP: IP Logged
PSPad:
Main Source:
Jer 1:5 Before I.
you can use a regular expression replacement and join the lines of this part after that:
Search for last digit, folowed by a space and any non-digit characters until the end of line; replace with that last digit and a semicolon:
(\d) \D*$
Replace with (regex)
$1;
After that, use
Edit: Lines manipulation: Join lines
(There is an extra semicolon at the end too in the result too.)
hth
#3 Re: Extract & Join - Bible verses, chapters etc.
Posted by: PSPad | Date: 2022-07-01 10:24 | IP: IP Logged
The expression is not fully compatible with extracting the verse. Any ideas to improve to extract the verses only?
([0-9]* {0,2}[A-Z]{1}\w+[,.;:]? {0,4}[xvilcXVILC\d]+[.,;:]( {0,2}[\d-,]{1,7})+)([,.;:] {0,4}[xvilcXVILC]*[.,;:]( {0,2}[\d-,]{1,7})+)*
biblehub.com
