You are here: PSPad forum > English discussion forum > Re: v5.0.7 where is Change Case option?
Posted by: therium | Date: 2022-05-19 11:27 | IP: IP Logged
I have PS Pad v5.0.7, English version, and I cannot see the Change Case to lowercase anywhere on the Edit menu. I swear it used to be there. I also looked on the keyboard shortcut mappings for everything on the Edit screen and it's not there either.
My file extension is .md, does that matter? I don't see the change case option for .txt files either. I do use that with some regularity.
Also on the edit menu I see some text for one item that is not English. Below Copy it says "Kopiravat formatovany text".
Could someone fix that missed translation please?
Thank you!
Edited 1 time(s). Last edit at 2022-05-19 11:28 by therium.
Posted by: pspad | Date: 2022-05-19 12:56 | IP: IP Logged
Kopirovat formatovaný text isn't missed translation, but missed code, what takes translated string. It's already fixed in my version
Upper case/Lower case/Capitalize/Invert... is in the menu Format / Char case change
