You are here: PSPad forum > English discussion forum > How to add new tags for hightlighting?
Posted by: nuker | Date: 2022-05-07 18:10 | IP: IP Logged
When you click on a tag such as <p> or <div> the program automatically will highlight the opening and closing tags. However, I found not all html are registered yet, specifically the newer ones such as <details>. How can I register them?
Thank you.
Posted by: pspad | Date: 2022-05-07 18:19 | IP: IP Logged
Mostly used tags was used. Highlighting is quite costly for page drawing so add all possible tags would slow down drawing. Currently are highlighted:
a, article, b, center, dd, div, dl, dt, em, font, footer, form, header, iframe, li, main, nav, noscript, ol, p, script, section, select, span, strong, table, tbody, td, th, tr, ul
If you need to add 1 or two tags, I can do it.
Posted by: nuker | Date: 2022-05-07 19:18 | IP: IP Logged
ahh i see. i think the option to add them yourself would be nicer so you can decide based on what you use the most.
thank you.
