You are here: PSPad forum > English discussion forum > Re: Hebrew font missing / problem display
#1 Hebrew font missing / problem display
Posted by: PSPad | Date: 2022-05-07 07:26 | IP: IP Logged
I need a font, but can't find it anywhere. Precise Name:
"GuttmanDVilna" or "GuttmanD Vilna"
It must be an identical name "D" for all characters to be displayed correctly on Windows 10.
#2 Re: Hebrew font missing / problem display
Posted by: pspad | Date: 2022-05-07 07:49 | IP: IP Logged
Any TTF font contains Hebrew characters.
Can you provide screenshots with wrong presentation of hebrew text with TTF font?
#3 Re: Hebrew font missing / problem display
Posted by: PSPad | Date: 2022-05-07 14:07 | IP: IP Logged
#4 Re: Hebrew font missing / problem display
Posted by: pspad | Date: 2022-05-07 15:03 | IP: IP Logged
What font is set in PSPad?
Is hebrew support installed in your Windows? Without it you can't write i hebrew.
#5 Re: Hebrew font missing / problem display
Posted by: PSPad | Date: 2022-05-07 16:47 | IP: IP Logged
I have tons of Hebrew fonts installed, lots of texts work great, but in this particular case, they don't. Because I don't have this format font. Adobe Acrobat Pro DC detects this as a "GuttmanD Vilna" format font
Edited 1 time(s). Last edit at 2022-05-07 16:48 by PSPad.
#6 Re: Hebrew font missing / problem display
Posted by: pspad | Date: 2022-05-07 16:57 | IP: IP Logged
Problem will be in encoding.
PDF sometimes uses semigraphic instead of chars - basic chars combined with graphics.
When yiu copy it into notepad, you see correctly hebrew text?
#7 Re: Hebrew font missing / problem display
Posted by: PSPad | Date: 2022-05-07 19:25 | IP: IP Logged
If I have the font installed it will display correctly.
I had the same with other fonts, I installed the correct format and everything displayed, so if anyone finds this font on the internet please give a download link.
