You are here: PSPad forum > English discussion forum > Re: Search / replace issue
Posted by: groston | Date: 2022-04-18 19:40 | IP: IP Logged
I created a new text file and pasted about 200 characters into it, including eight semi-colons dispersed throughout. I then hit ctrl-H, so that I could replace the semi-colons with new-lines. When I clicked OK, it says that eight semi-colons have been replaced, but it only replaces the first one. When I changed the new-line to some random text, it does replace all eight instances.
It seems to me that there is something not quite right when the text is being replaced with new-lines...
Posted by: vbr | Date: 2022-04-18 21:19 | IP: IP Logged
groston:I created a new text file and pasted about 200 characters into it, including eight semi-colons dispersed throughout. I then hit ctrl-H, so that I could replace the semi-colons with new-lines. When I clicked OK, it says that eight semi-colons have been replaced, but it only replaces the first one. When I changed the new-line to some random text, it does replace all eight instances.It seems to me that there is something not quite right when the text is being replaced with new-lines...
unfortunately, there are some limitations or quirks with regard to handling newlines for search and replace.
In this case a workaround can help:
Place the cursor at the end of the file and in the search and replace dialog set the Direction: (.) Backward. The replacement with newlines (\n in regex mode) should then work.
hth
Posted by: groston | Date: 2022-04-25 03:22 | IP: IP Logged
You are correct, thanks
