You are here: PSPad forum > English discussion forum > Re: Win11: How to dock Tool Panel on right side of PSPad window?
#1 Win11: How to dock Tool Panel on right side of PSPad window?
Posted by: therium | Date: 2022-04-14 11:27 | IP: IP Logged
Hello, my old PC crashed and I got a new PC with Windows 11. I have PSPad 5.0.6 (589) 64 bit.
When I show the Tool panel with CTL-F2, it appears on the left side of the window. When I try to drag the Tool Panel to the right side of PSPad window PSPad does not "grab" or dock the tool panel.
Is there a setting for the Tool Panel to make it dock on the right side of the PSPad window?
Thank you!
#2 Re: Win11: How to dock Tool Panel on right side of PSPad window?
Posted by: pspad | Date: 2022-04-14 11:39 | IP: IP Logged
Tool panel can't be dragged to the Right. On the right side can be dragged individual panels, but not all.
I suggest you to download current 5.0.7 build (32b version) from PSPad developer forum and replace existing files with content of the archive.
#3 Re: Win11: How to dock Tool Panel on right side of PSPad window?
Posted by: therium | Date: 2022-04-14 20:44 | IP: IP Logged
Why 5.0.7 and why 32 bit version? I'm curious.
Also, can I move the whole tool panel to the right? I can't seem to drag the whole tool panel with all tabs, but I can drag one tab, but it won't dock on the right side of PSPad.
Edited 1 time(s). Last edit at 2022-04-14 20:45 by therium.
#4 Re: Win11: How to dock Tool Panel on right side of PSPad window?
Posted by: pspad | Date: 2022-04-14 20:54 | IP: IP Logged
Because 5.0.7 is more stable than 5.0.6 and 32b causes less problems even sources are same
