You are here: PSPad forum > English discussion forum > Re: Is it possible to disable triple-click?
#1 Is it possible to disable triple-click?
Posted by: ieee | Date: 2022-04-01 08:35 | IP: IP Logged
I often invoke triple-click by mistake. Triple-click will select all data in the document and move cursor at the end. Is that possible to disable?
#2 Re: Is it possible to disable triple-click?
Posted by: pspad | Date: 2022-04-01 09:52 | IP: IP Logged
Just now it isn't possible, but it is possible to do in future build.
#3 Re: Is it possible to disable triple-click?
Posted by: ieee | Date: 2022-04-01 09:59 | IP: IP Logged
Many thanks!
#4 Re: Is it possible to disable triple-click?
Posted by: pspad | Date: 2022-04-01 10:50 | IP: IP Logged
Under program settings / Direct edit button will be new option:
TripleClick=0
This will disable triple and quadruple click behavior.
#5 Re: Is it possible to disable triple-click?
Posted by: ieee | Date: 2022-04-01 11:28 | IP: IP Logged
Fantastic... I just realize that I am not doing triple click accidentally but even quadruple click. Really strange smiling smiley
#6 Re: Is it possible to disable triple-click?
Posted by: ieee | Date: 2022-04-08 10:13 | IP: IP Logged
Works fine. Thanks a lot.
