You are here: PSPad forum > English discussion forum > Re: "replace" takes a long time
Posted by: Peter.eisentraeger2 | Date: 2022-03-30 08:03 | IP: IP Logged
I often have text files with 100k+ lines. While "Search and replace" pspad scrolls through the file and shows what happens. It works find but notepad++ does the job much faster. The same thing with "insert text into lines"
Posted by: pspad | Date: 2022-03-30 10:41 | IP: IP Logged
What PSpad version do you use?
Posted by: Peter.eisentraeger2 | Date: 2022-04-01 12:45 | IP: IP Logged
I use the latest 727 version
Posted by: Peter.eisentraeger2 | Date: 2022-04-13 09:01 | IP: IP Logged
I recently see another long time running thing. I search for a string and want to generate a list of the finds. This takes minutes for a 1,600,000 lines file. Isnt this done in memory? Why do the lines scroll through the window and the graphics card needs to show what happens? My PC isnt a weak on. 128GB RAM, 8core, 3.7GHz+, Nvidia P5000
Posted by: pspad | Date: 2022-04-14 11:56 | IP: IP Logged
Thank you for info. You are right, redraw slow down whole process. I disabled redraw for List and Copy. It should be much faster now.
