You are here: PSPad forum > English discussion forum > Re: Using command line options while pspad.exe is already running
Posted by: extrn | Date: 2022-03-04 19:51 | IP: IP Logged
When I try to execute a command
> pspad -F text_to_search filename.txt
to open another file while pspad process is already running, the command line options are interpreted as file names.
So pspad tries to open files "-F", "text_to_search" and "filename.txt"
if the process is not running, the command line options work as expected.
Posted by: pspad | Date: 2022-03-04 20:01 | IP: IP Logged
Pspad version?
Try to use pspad.exe instead of pspad in command line
Posted by: extrn | Date: 2022-03-04 20:32 | IP: IP Logged
Latest version 5.0.6 (x64)
Windows 7 (x64)
I also tried
> PSPad.exe -F text_to_search filename.txt
and
> "C:\Program Files\PSPad editor\PSPad.exe" -F text_to_search filename.txt
with the same result
when I created the windows shortcut file with command line
the result was even more unexpected: pspad tried to open "Program", "PSPad", "-F", "text_to_search" and "filename.txt"
Posted by: extrn | Date: 2022-03-04 20:47 | IP: IP Logged
"C:\Program", "Files\PSPad", "editor\-F", "text_to_search" and "flename.txt"
to be exact
Posted by: pspad | Date: 2022-03-05 05:42 | IP: IP Logged
Try please 5.0.7 from developer forum. I will check it too
Posted by: extrn | Date: 2022-03-05 07:57 | IP: IP Logged
same problem (both x86 and x64) :(
Here is some related issue
Running the program for the first time:
C:\>cd C:\some_folder
C:\some_folder>C:\pspad507\PSPad.exe 1.txt 2.txt
"C:\some_folder\1.txt" and "C:\some_folder\2.txt" are opened as expected
Then while process is running:
C:\some_folder>cd C:\another_folder
C:\another_folder>C:\pspad507\PSPad.exe 3.txt 4.txt
"C:\another_folder\3.txt" and "C:\some_folder\4.txt" are opened
Now I'm closing all files (pspad is still running). And once again:
"C:\another_folder\3.txt" and "C:\pspad507\4.txt" are opened
Things get even worse when there are spaces in the work path
C:\some_folder>cd "C:\another folder with spaces"
C:\another folder with spaces>C:\pspad507\PSPad.exe 1.txt 2.txt
Opened files:
C:\another
C:\some_folder\folder
C:\some_folder\with
C:\some_folder\spaces\1.txt
Closing files, repeat:
Opened files:
C:\another
C:\pspad507\folder
C:\pspad507\with
C:\pspad507\spaces\1.txt
C:\pspad507\2.txt
Posted by: pspad | Date: 2022-03-17 13:53 | IP: IP Logged
extrn:When I try to execute a command
> pspad -F text_to_search filename.txtto open another file while pspad process is already running, the command line options are interpreted as file names.
So pspad tries to open files "-F", "text_to_search" and "filename.txt"if the process is not running, the command line options work as expected.
I just test it. It works for me even PSpad isn't running or is already running and file is/isn't open
You can prevent all problems with your command line parameters to write at least PSPad.exe, not pspad only and the best is to use whole path to pspad.exe and to your files. If there is long path with spaces, use quotes.
Imagine:
PSpad is running. You call PSPad with some parameters without any paths.
Windows starts new PSpad instance with parameters you sent. PSPad must send parameters into existing instance but their work directory is different.
Try to use your examples and use at least pspad.exe
Posted by: halweg | Date: 2022-05-25 08:55 | IP: IP Logged
This thread seems to be near to my problem so I hope it's not a problem to reuse it.
I usually open pspad with
<pspad.exe-path> /FR "<searchstring>" "file-path"
This works fine and I can i.e. open a second pspad window with a library file using a searchstring from the first one.
The problem is that a second call of this command line opens a second window with the library file and a new instance of pspad. So editing the second file is no more possible cause risk of inconsistencies.
I know that I can avoid the problem when allowing only one instance of pspad. But this way it isn't possible to have two separate pspad windows side by side (on different monitors) what is very important for my overview.
Is there an option to find a string inside an open pspad window by command line? Or just to avoid open a second window with the same file?
Posted by: pspad | Date: 2022-05-25 10:13 | IP: IP Logged
Patience please. Your problem is in my evidence. First I have to solve some serious problems that do not concern the PSPad. Work on PSpad is slow now.
