You are here: PSPad forum > English discussion forum > Re: PSPad's dark theme
Posted by: Y-Phil | Date: 2022-01-10 11:04 | IP: IP Logged
Hi
Happy New Year
First: I wanted to thank you all for PSPad, my favorite program <3
Then: since I installed the v5.0.7 (723), I lost my dark theme. I'd like to know what I've done wrongly.
Kind regards
Y-Phil
Posted by: pspad | Date: 2022-01-10 13:09 | IP: IP Logged
Themes in PSpad causes most of the problems in 5.0.5 and 5.0.6
5.0.7 is without theme support. I need to stabilize this version first, as second step I must find way how to add themes without influences of stability.
Posted by: X-Byte | Date: 2023-03-10 20:08 | IP: IP Logged
Hi, is there any update on the progress of bringing theme support back to pspad (especially a real pspad dark mode)?
Posted by: kyros | Date: 2023-03-15 20:05 | IP: IP Logged
After updating to version 5.0.7 (770) I lost the dark mode, although there was no change in the INI. (using Windows 11). In Windows dark mode is set (all other application are in dark mode.
Posted by: DelphiErik | Date: 2023-03-24 11:03 | IP: IP Logged
Hi, could you bring theming of the IDE (dark mode) back to the most recent (beta) version? Maybe with the addition as "experimental" (or hidden and only be set in ini-file). In version 5.0.6 it was not perfect but it was doable. I know the color scheme can be set to dark, but that looks really bad in combination with the light/classic IDE colors. Thanks!
Posted by: pspad | Date: 2023-03-24 11:18 | IP: IP Logged
I just testing styles to bring it back.
Posted by: X-Byte | Date: 2023-03-24 13:53 | IP: IP Logged
pspad:HelloI just testing styles to bring it back.
Thanks for the reply and still following up with bringing dark mode/theme back
Posted by: pspad | Date: 2023-03-24 16:54 | IP: IP Logged
Just now I have problem with 64b version.
So I will support themes in 32b version only till problem will be solved.
I will publish new build as soon as possible
Posted by: X-Byte | Date: 2024-03-01 22:19 | IP: IP Logged
Have you been able to solve the problem in the meantime so themes are available in the 64 bit version too?
