You are here: PSPad forum > English discussion forum > Re: XML "Code Explorer Window" Expand all tabs when save
#1 XML "Code Explorer Window" Expand all tabs when save
Posted by: emilianofeijoo | Date: 2021-12-31 01:58 | IP: IP Logged
Hi everyone!
I have a doubt related to how can I set PSPad to avoid expanding all entries in the "Code explorer window" when I save changes in my XML.
I'm working with a very hugh .XML file and some entries I need to keep collapsed and others keep expanded. When I finish doing it, I do some changes in the .XML file, save the file and after that, all the entries in "Code Explorer Window" are all expanded again.
My question is how can I set it in the PSPad to avoid it.
Please, anyone could let me know?
Thanks and regards.
Emiliano Feijoo
#2 Re: XML "Code Explorer Window" Expand all tabs when save
Posted by: pspad | Date: 2021-12-31 06:14 | IP: IP Logged
I don't know what PSPad version do you use, but PSPad should remember collapsed/expanded state of current code explorer nodes.
