You are here: PSPad forum > English discussion forum > Re: Large file support
#1 Large file support
Posted by: David.Moore | Date: 2021-12-22 14:56 | IP: IP Logged
I have tried to use PSPAD with a large web server log file (which PSPAD reports is 1063 MB) and the message 'cannot open file ... integer overflow' is displayed.
Is there any way to address this - or alternative editors such as 'vim' or 'ultraedit' need to be used instead?
#2 Re: Large file support
Posted by: pspad | Date: 2021-12-22 15:05 | IP: IP Logged
Did you try 64b PSpad version?
I suggest this one:
forum.pspad.com
Do you really need to EDIT such big file? If not, use any viewer. Viewer is much easier, cause it doesn't need to take care of editing, it displays file part by part.
Edited 1 time(s). Last edit at 2021-12-22 15:06 by pspad.
