You are here: PSPad forum > English discussion forum > Re: How do I install an extension?
Posted by: Joel | Date: 2021-12-13 18:07 | IP: IP Logged
I found a thread that gave a very basic instructions, but it was written 4 years ago, and the instructions didn't match.
How do I install an extension in PSPad version 5.0.6?
Posted by: pspad | Date: 2021-12-13 20:54 | IP: IP Logged
The condition is 32b version, 64b version doesn't support scripting yet.
In the program settings / System scripting must be enabled.
In this case you will see Script menu with all scripts
Your script file you downloaded place int PSPad\Script\<language name> folder.
VB files into VBScript folder, JS files into JavaScript folder
I hope we are talking about this kind of extensions
Posted by: Mystral | Date: 2022-06-15 11:27 | IP: IP Logged
Does the 64b version will have Scripts feature in the future ?
Regards
The civility starts by the communication
