You are here: PSPad forum > English discussion forum > Indelible vertical line !
#1 Indelible vertical line !
Posted by: New user | Date: 2021-11-14 09:34 | IP: IP Logged
I am using PSPad for the first time but I have a problem!
I don't want this vertical line to appear.
What should I do for this?
Here it; ibb.co
#2 Re: Indelible vertical line !
Posted by: pspad | Date: 2021-11-14 09:46 | IP: IP Logged
In the program settings / Editor set Right edge to zero or to 1024
This line can be used for reformat paragraph, wrap lines e.t.c.
#3 Re: Indelible vertical line !
Posted by: naputtelija | Date: 2021-11-15 05:12 | IP: IP Logged
I would like to see a setting that would disable this feature. I get vertical line too often accidentally, never on purpose.
#4 Re: Indelible vertical line !
Posted by: pspad | Date: 2021-11-15 05:30 | IP: IP Logged
Set position of the right edgevto zero. It's too complicated?
