You are here: PSPad forum > English discussion forum > Re: Multiple projects open at the same time
#1 Multiple projects open at the same time
Posted by: ser45 | Date: 2021-11-08 10:36 | IP: IP Logged
I have not been able to find out how to do the above. One (old) suggestion was to have multiple instances of PSPad running, but the Program Settings -> System Integration menu will not allow me to uncheck "Only One Program Instance" (there is a red dot beside it). Is there another way?
#2 Re: Multiple projects open at the same time
Posted by: pspad | Date: 2021-11-08 10:38 | IP: IP Logged
If application is installed in program files, some options require to write into program folder.
Start PSpad as admin, change settings and save it. Than start PSpad normally
#3 Re: Multiple projects open at the same time
Posted by: ser45 | Date: 2021-11-09 19:22 | IP: IP Logged
Many thanks.
