You are here: PSPad forum > English discussion forum > Migrate 32Bit to 64Bit
Posted by: urmel | Date: 2021-10-22 12:30 | IP: IP Logged
I realized that there are "problems" when migrating 32Bit PSPad to 64Bit PSPad.
When Updateing the 32Bit to 64Bit Version there is no check done ...Hey you, you have a 32Bit Version installed. Do you want to remove? Or do you want to Migrate to 64Bit?
It took a while to see I have installed the 32Bit Verion as well.
Then the 32Bit Update Message appeard several times and I have not realize my mistake.
My wish, Please:
Can you add, may be, into the installation process a 64Bit check or on 32Bit installation process to give a warning, 32 or 64 is installed?
Do you want to add or to remove the different Version?
Or you will use both versions?
Something like this would be great
Thanks with best regards
Urmel
Posted by: pspad | Date: 2021-10-22 13:12 | IP: IP Logged
Both version can be installed together, 32b version is installed in the program files (x86) folder, 64b version in the program files folder.
Config files are shared for both version in the %appdata%\pspad path
I will look what I can do in the installer.
Posted by: canadaescorts | Date: 2021-12-28 04:43 | IP: IP Logged
How to extract the correct final link to the full-size photo.
I have a list of links but I need regular expressions.
Posted by: pspad | Date: 2021-12-28 04:58 | IP: IP Logged
Write your question with link examples into new thread. It has nothing to do with the 32b or 64b
