You are here: PSPad forum > English discussion forum > Illegal access crash
Posted by: rvinea | Date: 2021-09-27 09:31 | IP: IP Logged
For sometime now, pspad often crashes with "illegal access" message. It is only possible to kill the program via task manager. Re-installing the program does not help. I've ignored this "minor" annoyance hoping that it would be solved with new releases, but this has not happened yet so I am wondering if anyone else is having similar issues.
Posted by: pspad | Date: 2021-09-27 09:43 | IP: IP Logged
Your PSPad version and build?
Posted by: rvinea | Date: 2021-09-27 10:33 | IP: IP Logged
This happens both with the last official build 5.0.6 and with the current developer build 625. Both are 32bit versions.
Posted by: pspad | Date: 2021-09-27 10:43 | IP: IP Logged
Current developer build is 681
Posted by: rvinea | Date: 2021-09-29 08:38 | IP: IP Logged
Updated to 681, same behavior.
Posted by: pspad | Date: 2021-09-29 09:08 | IP: IP Logged
Do you use 32b version? If not, replace content with 32b please
