You are here: PSPad forum > English discussion forum > Re: Still getting Access violation errors
Posted by: ssarber | Date: 2021-07-28 20:49 | IP: IP Logged
I did the following and I'm still getting these errors:
Access violation at address ...
Is anyone else still having issues? PSPad won't even let me close the program, I have to shut down and restart.
Sandy
Posted by: pspad | Date: 2021-07-29 03:14 | IP: IP Logged
Do you use 64b or 32b version?
Delete pscache5.bin file in the %appdata%\pspad folder
Check if recent.ini file (same location) isn't corrupted
Posted by: ssarber | Date: 2021-08-03 14:50 | IP: IP Logged
64 bit
Posted by: pspad | Date: 2021-08-03 17:34 | IP: IP Logged
And other 2 steps?
Posted by: rvinea | Date: 2021-09-27 07:38 | IP: IP Logged
Yes, same problem here. The only way out is to kill pspad through the task manager. Deleting pspad and reinstalling does not help.
Posted by: pspad | Date: 2021-09-27 07:45 | IP: IP Logged
One question is enough. Please your PSPad version and build?
Do you use current developer 32b build?
