You are here: PSPad forum > English discussion forum > Unable to extract all urls if the file is 27 MB large (JSON)
#1 Unable to extract all urls if the file is 27 MB large (JSON)
Posted by: Haunebu | Date: 2021-07-20 00:34 | IP: IP Logged
Unable to extract all urls if the file is 27 MB large JSON File. The application is completely unresponsive to commands. PSPad is completely unresponsive, frozen.
PSPad all time 25% CPU
angry smileyangry smileyangry smiley
#2 Re: Unable to extract all urls if the file is 27 MB large (JSON)
Posted by: pspad | Date: 2021-07-20 03:36 | IP: IP Logged
If your 27MB JSON file is one line file, find another tool or reformat it first.
#3 Re: Unable to extract all urls if the file is 27 MB large (JSON)
Posted by: therium | Date: 2021-08-05 10:55 | IP: IP Logged
Hi OP. I'm a programmer. There may be limits to the widgets that the author uses for PSPad. Please follow his advice. His advice is correct.
