You are here: PSPad forum > English discussion forum > Re: Integrated scripting support WSH striked through
#1 Integrated scripting support WSH do not work in 64-bit version
Posted by: edo_nick | Date: 2021-07-01 10:46 | IP: IP Logged
Hello, after upgrading to 5.0.6(589) all my scripts disappeared from script menu. Only "recompile scripts" remains.
When I check program settings/system integration there is Integrated scripting support (WSH) checked and striked through.
Where is problem?
Edited 1 time(s). Last edit at 2021-09-10 09:22 by Stefan.
#2 Re: Integrated scripting support WSH striked through
Posted by: pspad | Date: 2021-07-01 11:14 | IP: IP Logged
Scripting isn't supported in 64b version yet.
#3 Re: Integrated scripting support WSH striked through
Posted by: edo_nick | Date: 2021-07-01 11:53 | IP: IP Logged
So install 32-bit version is the solution.
#4 Re: Integrated scripting support WSH striked through
Posted by: pspad | Date: 2021-07-01 11:59 | IP: IP Logged
Exactly. 64b application doesn't bring any advantages in compare to 32b for such type of application as PSPad is. But it's "trend"
