You are here: PSPad forum > English discussion forum > Re: Indentation and autoreplace
#1 Indentation and autoreplace
Posted by: idefix2 | Date: 2021-05-31 16:26 | IP: IP Logged
It still happens that after an autoreplace, the indentation gets partially lost.
This is the screen before I hit the enter key:
ibb.co
ANd this is the screen after hittin enter:
ibb.co
PS: The img tags in this forum don't seem to work. Instead of the linked picture, only the word "image" is displayed. I have added the second link under the img tags to show.
Edited 2 time(s). Last edit at 2021-05-31 16:30 by idefix2.
#2 Re: Indentation and autoreplace
Posted by: pspad | Date: 2021-05-31 17:24 | IP: IP Logged
Do you use real tabs?
#3 Re: Indentation and autoreplace
Posted by: pspad | Date: 2021-06-01 20:17 | IP: IP Logged
I hope it was fixed with another report.
I tested it and all looks OK.
#4 Re: Indentation and autoreplace
Posted by: idefix2 | Date: 2021-06-07 09:50 | IP: IP Logged
No, I use soft tabs
I was away for a few days, sorry for not answering earlier. I'll try the latest version and give feedback afterwards.
#5 Re: Indentation and autoreplace
Posted by: idefix2 | Date: 2021-06-07 15:53 | IP: IP Logged
The problem seems to be solved, thank you
