You are here: PSPad forum > English discussion forum > Re: File handling plugin stopped working
Posted by: klr98298 | Date: 2021-05-27 18:00 | IP: IP Logged
I had a custom PSPad file handling pluging that was working fine on previous versions at least up to 5.0.7(600), but after upgrading to 5.0.7(638) I get an access violation exception (0xc0000005) in PSPad when I try to open the file types associated to that plugin.
The plugin itself is nothing too special, basically a batch script (compliant with the PSPad plugin API) which calls a command line tool to decrypt or encrypt files (on read and write operations, respectively).
Has anything changed related to plugin management (maybe more strict timeouts, process (de)coupling or something like that?
Thanks for the support.
Posted by: pspad | Date: 2021-05-28 03:53 | IP: IP Logged
I didn't make any changes. I will look what can be worng in plugins handling.
Posted by: pspad | Date: 2021-05-28 05:19 | IP: IP Logged
I found problem what can cause it.
Fix will be available in this weekend's build
Posted by: klr98298 | Date: 2021-05-30 09:07 | IP: IP Logged
I can confirm that my custom file handling plugin seems to be worfing fine again after the fixes introduced in the new version 5.0.7(643).
Thank you for the responsive support!
