You are here: PSPad forum > English discussion forum > Re: Please help complex Java regex
#1 Please help complex Java regex
Posted by: Haunebu | Date: 2021-04-23 19:33 | IP: IP Logged
I want correct Match URL (Java regex)
example.com
example.com
AND
example.com
My wrong escape and wrong url delimiter
https:\\example\\.com/(20[01][0-9]|2020)/0*([1-9]|1[0-2])/(\d+[-/]\d+)|https:\\example\\.com/diary/(.*)/(\d+)-(\d+)-(\d+)
Edited 1 time(s). Last edit at 2021-04-23 19:33 by Haunebu.
#2 Re: Please help complex Java regex
Posted by: pspad | Date: 2021-04-23 19:46 | IP: IP Logged
Start with fix of / and \
#3 Re: Please help complex Java regex
Posted by: pspad | Date: 2021-04-23 19:54 | IP: IP Logged
https://example.com/(diary/example/){0,1}20[01][0-9]([/-]\d{2}){2}([/-]\d+){0,1}
#4 Re: Please help complex Java regex
Posted by: Haunebu | Date: 2021-04-23 20:02 | IP: IP Logged
Edit.. My mistake
Not java Regex
JSON regex
json-schema.org
#5 Re: Please help complex Java regex
Posted by: Haunebu | Date: 2021-04-23 20:08 | IP: IP Logged
Error:
is not a valid 'java.util.List
#6 Re: Please help complex Java regex
Posted by: pspad | Date: 2021-04-23 20:25 | IP: IP Logged
If you request it for Java, visit any Java forum. This forum is for PSPad support and my regexp works correctly in PSPad
#7 Re: Please help complex Java regex
Posted by: Haunebu | Date: 2021-04-23 20:40 | IP: IP Logged
NO MATCH
Edited 2 time(s). Last edit at 2021-04-23 20:41 by Haunebu.
#8 Re: Please help complex Java regex
Posted by: pspad | Date: 2021-04-23 20:44 | IP: IP Logged
I don't cate for you testing web. I provided correct regexp for pspad.
If you won't stop use pspad forum for your personal activities not related with pspad, your account will be deactivated.
I markex this topic as solved and closed
This Thread has been closed
