You are here: PSPad forum > English discussion forum > Re: Drag file into editor, 5.0.6 64 Bit
#1 Drag file into editor, 5.0.6 64 Bit
Posted by: peter65 | Date: 2021-04-15 10:07 | IP: IP Logged
What do I have to do to be able to drag files from the Explorer into the Editor?
Until today I used the 32-bit version, there was no problem.
Peter
#2 Re: Drag file into editor, 5.0.6 64 Bit
Posted by: pspad | Date: 2021-04-15 11:19 | IP: IP Logged
Tested with current 5.0.7 64b and it works for me
#3 Re: Drag file into editor, 5.0.6 64 Bit
Posted by: Andreas | Date: 2021-04-16 07:47 | IP: IP Logged
It doesn't work anymore since 5.0.7 593 32 bit
#4 Re: Drag file into editor, 5.0.6 64 Bit
Posted by: pspad | Date: 2021-04-16 08:13 | IP: IP Logged
Just tested with both version 32 and 64.
I don't remember I changed anything in my current version in compare to last published build, but everything is possible. We will see after this weekend build
#5 Re: Drag file into editor, 5.0.6 64 Bit
Posted by: Stefan | Date: 2021-04-27 13:36 | IP: IP Logged
peter65:
Peter
Do not run PSPad as administrator if you want to drag from WinExplorer.
WindowsTM didn't allowing drag&drop from lower integrity level into program with higher IL.
Google for "vista integrity level"
