You are here: PSPad forum > English discussion forum > Re: v5.06 - won't start from text file double-click
Posted by: joemarfice | Date: 2021-04-12 16:58 | IP: IP Logged
When launching PSPad by double-clicking on a text file in File Explorer (with PSPad set as the default text editor, obviously), I get the following error in a popup:
Quote:Error reading StatusBar.Left: Cannot create form. No MDI forms are currently active.
The file does not load.
When attempting to then close PSPad after dismissing this error, I get a new popup:
Quote:Cannot change Visible in OnShow or OnHide.
I cannot close PSPad except by using Task Manager.
NOTE: v5.07b593 (developer's release) fixes this problem, but I'm still reporting it so anyone else can see the solution.
Posted by: pspad | Date: 2021-04-12 17:08 | IP: IP Logged
5.0.6 was updated with some fixes. Did you use the updated version?
Posted by: joemarfice | Date: 2021-04-12 22:43 | IP: IP Logged
No idea. That's not really visible to users, since the rev was the same, and the download site doesn't list the build # AFAICT.
Posted by: pspad | Date: 2021-04-12 22:45 | IP: IP Logged
Menu help / check for new version
