You are here: PSPad forum > English discussion forum > Re: I am looking for a special pattern "Bible Verse Regex"
Posted by: Haunebu | Date: 2021-04-10 08:17 | IP: IP Logged
Please show the screenshot that all characters are matched fully in Application of the PSPad. Because even without text, the regular expression is incorrect.
Posted by: pspad | Date: 2021-04-10 08:42 | IP: IP Logged
Provide more complex text examples please with some text arround and mark what do you want to find.
Posted by: Haunebu | Date: 2021-04-10 10:45 | IP: IP Logged
All characters should be matched
(Rdz 1:9, 10, 13; Neh 9:6; Dz 4:24; 14:15; Obj 14:7)
Posted by: pspad | Date: 2021-04-10 11:10 | IP: IP Logged
Read again and slowly my previous answer.
Posted by: Haunebu | Date: 2021-04-10 13:02 | IP: IP Logged
It's better not to explain. As you can see the pattern to match only the characters in red.
It should match a total of 52 characters
Edited 2 time(s). Last edit at 2021-04-10 13:04 by Haunebu.
Posted by: Haunebu | Date: 2021-04-10 15:57 | IP: IP Logged
Invalid Bible Verse Regex
([a-žA-Ž0-9.]+\s+)+([0-9:.,;-]+\s{0,})+[0-9]
Edited 1 time(s). Last edit at 2021-04-10 15:58 by Haunebu.
Posted by: vbr | Date: 2021-04-10 17:56 | IP: IP Logged
Haunebu:Invalid Bible Verse Regex
Hi, if you want to avoid such "false positive" matches, which are not meaningful for you, the individual book names as well as abbreviations and variants will be needed in such a regex pattern.
Also, matching multiple citations to different books or places in one match is rather difficult or error prone with regex.
A possibility could be, to match the general format of the citation, if there is one - e.g. parens, colons, numbers in specified expected positions.
Note, that the accented characters are not treated alphabetically here, but most likely as codepoints in unicode, i.e.
[a-žA-Ž]
will match e.g. the following characters:
A...Z [ \ ] ^ _ ` a...z { | } ~ ¡ ¢ £ ¤ ¥ ¦ § ¨ © ª « ¬ ® ¯ ° ± ² ³ ´ µ ¶ · ¸ ¹ º » ¼ ½ ¾ ¿ À Á Â Ã Ä Å Æ Ç È É Ê Ë Ì Í Î Ï Ð Ñ Ò Ó Ô Õ Ö × Ø Ù Ú Û Ü Ý Þ ß à á â ã ä å æ ç è é ê ë ì í î ï ð ñ ò ó ô õ ö ÷ ø ù ú û ü ý þ ÿ Ā ā Ă ă Ą ą Ć ć Ĉ ĉ Ċ ċ Č č Ď ď Đ đ Ē ē Ĕ ĕ Ė ė Ę ę Ě ě Ĝ ĝ Ğ ğ Ġ ġ Ģ ģ Ĥ ĥ Ħ ħ Ĩ ĩ Ī ī Ĭ ĭ Į į İ ı IJ ij Ĵ ĵ Ķ ķ ĸ Ĺ ĺ Ļ ļ Ľ ľ Ŀ ŀ Ł ł Ń ń Ņ ņ Ň ň ʼn Ŋ ŋ Ō ō Ŏ ŏ Ő ő Œ œ Ŕ ŕ Ŗ ŗ Ř ř Ś ś Ŝ ŝ Ş ş Š š Ţ ţ Ť ť Ŧ ŧ Ũ ũ Ū ū Ŭ ŭ Ů ů Ű ű Ų ų Ŵ ŵ Ŷ ŷ Ÿ Ź ź Ż ż Ž ž ſ Μ
Mostly, it catches many basic and accented Latin characters, but also some non-characters which happen to have codepoints between A and ž, and there are some other specificities as well.
I'd suggest to use some rather general pattern based on the citation format (if possible without false negatives, i.e. missing useful matches) and work with the false (positive) matches in further steps.
hth,
Edited 1 time(s). Last edit at 2021-04-10 17:57 by vbr.
Posted by: Haunebu | Date: 2021-04-11 11:36 | IP: IP Logged
vbr. Completely unnecessary ALL UNICODE!
No, it was PSPad (administrator) that mistakenly suggested to use [A-Z] (unicode), which is not recommended here!
This is a totally wrong pattern. And it doesn't matter whatever language is used.
This is the best pattern, but requires several patches for a combination of multinumbers, multispaces, multisemicolons REPEAT and brackets
(;)s0-9
(?:\d|I{1,3})?\s?\w{2,}\.?\s*\d{1,}\:\d{1,}-?,?\d{0,2}(?:,\d{0,2}){0,2}
Edited 5 time(s). Last edit at 2021-04-11 11:44 by Haunebu.
Posted by: pspad | Date: 2021-04-11 12:54 | IP: IP Logged
Sorry, I tried to help you. My solution doesn't fit to you, it's OK for me.
You have as much time as you need to tune up your expression.
But in my opinion, your search pattern are too different. It will be very hard to use one regular expression to match all form you reguested.
Posted by: Haunebu | Date: 2021-04-11 15:23 | IP: IP Logged
Be kind to show me a screenshot of the PSPad application where you matched my verses from the first post to your pattern.
