You are here: PSPad forum > English discussion forum > Set Line Numbers
Posted by: rbon | Date: 2021-04-03 20:47 | IP: IP Logged
Hi Jan,
I use PSPad Portable 32 bit and I like to use Line Numbers.
I have edit the file KeyMap.ini -> section [Show] -> item aLineNum=1.
This modification works, but I don't knows if value '1' is correct or if I must use another value.
When I use -> View -> Line Numbers -> and I toogle it, number 1 remains.
Any suggestions ?
Posted by: pspad | Date: 2021-04-03 21:02 | IP: IP Logged
Placement of the config files depends of the Program settings / System integration / Multiuser environment.
If disabled, PSpad is in portable mode and stores all config files in PSPad folder
If enabled, config files are stored in %AppData%\PSPad
Option, you are looking for is stored in PSPad.INI, not in the KeyMap.ini
Notes:
1. No application has rights to write into Program files folder. If you extracted PSpad into Program files, start PSPad as admin, enable Program settings / System integration / Multiuser environment option
This will move config into %AppData%\PSPad and PSpad will be able to store settings
2. Don't edit PSPad.INI in PSPad, casue PSPad read it on the start and writes when finish, so all changes you will made will be lost
3. Value 0/1 in INI files means False/True, if the variable is boolean type
Edited 2 time(s). Last edit at 2021-04-03 21:04 by pspad.
