You are here: PSPad forum > English discussion forum > Re: PSPad Portable 5.0.5 (567) 32 and 64 bit
Posted by: rbon | Date: 2021-03-02 21:23 | IP: IP Logged
Hi Jan,
I have downloaded both portable build 32 and 64 bit.
Why the size of PSPad.exe is the same in 32 and 64 bit ?
I had seen ver 5.0.5 (561) and PSPad.exe for 64 bit was bigger.
Where are differences between two versions ?
Thanks.
Posted by: pspad | Date: 2021-03-02 21:34 | IP: IP Logged
You are right, size of the 64b should be bigger. I will check it tomorrow, I am out of computer now.
Posted by: pspad | Date: 2021-03-03 06:43 | IP: IP Logged
64b portable version package was fixed
