You are here: PSPad forum > English discussion forum > .log file current line is not highlighted
#1 .log file current line is not highlighted
Posted by: therium | Date: 2021-02-25 18:47 | IP: IP Logged
I have PSPad 5.0.0 on Windows 10.
I have a .log file in the windows File Explorer, so I right clicked the .log file, chose PSPad, and PSPad opened the file. Under Settings, Program Settings, Colors, the Current Line setting shows yellow, but there is no yellow highlight in the actual PSPad file.
I already went into Current Line and changed the colors, then quit PSPad, and right clicked the .log file and opened it again. There is still no current line highlight.
I do not think .log files are registered for PSPad.
Does anyone know how to fix this?
#2 Re: .log file current line is not highlighted
Posted by: pspad | Date: 2021-02-25 19:00 | IP: IP Logged
Please ensure that you have switched on current line highlight in the menu view.
In defaut it's on. Maybe you accidentally switched it off
#3 Re: .log file current line is not highlighted
Posted by: therium | Date: 2021-02-25 19:24 | IP: IP Logged
That was it. Problem solved. Menu option is View, Active line.
Thank you!
