You are here: PSPad forum > English discussion forum > Re: Quick Access Bar
#1 Quick Access Bar
Posted by: XMacroLister | Date: 2021-02-02 13:45 | IP: IP Logged
Microsoft Word and Excel (and others) allow the user to customize the Quick Access Bar and the Ribbon.
I would like to customize PSPad's Quick Access and/or Ribbon to be able to include an often used DSpellCheck Plugin.
Every time I need to search for the next misspelling I have to first select the Plugins dropdown, then select the DSpellCheck, and finally select the Find Next Misspelling.
What a waste of valuable time for checking the misspelling of hundreds of XML line code.
Is there a way to add a quick pick for this oft used function?
Never mind, I just realized this topic involves Notepad++
When an XML file is opened in Notepad++ it looks eerily similar to the GUI of PSPad
Edited 3 time(s). Last edit at 2021-02-02 13:51 by XMacroLister.
#2 Re: Quick Access Bar
Posted by: pspad | Date: 2021-02-02 13:49 | IP: IP Logged
Are you sure you write about PSPad?
PSpad doesn't use DSpell. Where do you "select" it? There is no plugin menu.
P.S. I see, it's for Notepad++
Edited 1 time(s). Last edit at 2021-02-02 13:50 by pspad.
#3 Re: Quick Access Bar
Posted by: pspad | Date: 2021-02-02 13:53 | IP: IP Logged
PSpad has own spellcheck, you can easily to call is with F7 shortcut or let PSPad underline misspell words like in the Word.
You need to download and unpack dictionaryu from PSPad web download page, put it into Spell subfolder and set in menu Settings / Spell check settings (Ctrl+F7)
#4 Re: Quick Access Bar
Posted by: XMacroLister | Date: 2021-02-02 14:04 | IP: IP Logged
Well maybe if there was a tool in PSPad to check for misspellings or an online source to add to PSPad that would be awesome.
Anyone know about this so I can do my spellchecking in PSPad?
OOPS, sorry, I was a bit too fast in this post. Did not see your post about adding spellcheck ability to PSPad.
I will check this out and let you know how it goes.
Edited 1 time(s). Last edit at 2021-02-02 14:05 by XMacroLister.
#5 Re: Quick Access Bar
Posted by: XMacroLister | Date: 2021-02-02 14:16 | IP: IP Logged
Works like a charm, thank you so much for your help.
