You are here: PSPad forum > English discussion forum > Re: how to use multiline?
#1 how to use multiline?
Posted by: poopiepoop | Date: 2021-01-07 13:10 | IP: IP Logged
after update, i have noticed that when i highlight text with shift, it highlights all the occurences of the string, which is great!
but how do i actualy use it? how to then confirm/multiselect the multi-highlighted text? i can rewrite only the original selected text and can't figure out hotkey that would edit them all/can't find it in the hotkey settings
#2 Re: how to use multiline?
Posted by: pspad | Date: 2021-01-07 13:15 | IP: IP Logged
There is no multiselect edit implemented yet
#3 Re: how to use multiline?
Posted by: poopiepoop | Date: 2021-01-07 21:54 | IP: IP Logged
oh ok, thanks for the response
and what purpose is of this multi line highlight then? or is it just to visually show the same lines on the same screen?
#4 Re: how to use multiline?
Posted by: pspad | Date: 2021-01-07 22:01 | IP: IP Logged
The reason is show all occurences of selected/found text
