You are here: PSPad forum > English discussion forum > Another wishlist,
Posted by: pspad | Date: 2021-01-28 19:28 | IP: IP Logged
idefix2:"Mouse wheel in text diff window"That is a misunderstanding, I am not speaking of the text diff window. In that window, the two sides are synchronized, that is ok.
I am speaking of "window - vertical split". This mode is very useful for seeing two different places of the same file at the same time. And in this mode, the mouse wheel does not work as expected.
Mouse wheel in splitted window
Thank you for explanation. Problem found and fixed. Wait for next build.
Posted by: idefix2 | Date: 2021-01-28 20:25 | IP: IP Logged
Well, now I tried to reproduce the problem with indented text, but it does not appear anymore, not even in AHK files.
If the problem appears again, I will try to isolate it, so that it becomes reproduceable.
"Mouse wheel in splitted window"
Thank you!
Edited 1 time(s). Last edit at 2021-01-28 20:27 by idefix2.
