You are here: PSPad forum > English discussion forum > Re: Integration of PSPad in Windows explorer
#1 Integration of PSPad in Windows explorer
Posted by: FrankRose | Date: 2020-12-31 14:21 | IP: IP Logged
Is it possible to disable the integration of PSPad in the Windows explorer (context menu)? Thank you very much!
#2 Re: Integration of PSPad in Windows explorer
Posted by: pspad | Date: 2020-12-31 15:35 | IP: IP Logged
Program settings / System integration
Switch it off
But 7Zip and CRC SHA isn't related to PSPad
Edited 1 time(s). Last edit at 2020-12-31 15:36 by pspad.
